ls-1 vs 6.0 questions?
i have a couple of questions. i have a ls-1 bare block and a 6.0 bare block. i am currently converting my camaros v6 into a ls-1. what would be the benafits to using my the 6.0 instead of the ls-1 block? will stock ls-1 pistons fit the 6.0? can i use the 6.0 crankshaft? and i have the lq9 heads and am having the compression bumped up match z06 heads, what type of cam would you guys recomend to get the most hp out of my set up? i would really appreciate some help and advice.
The 6.0 has a bigger bore so the ls1 pistons will not work with the 6.0 block. The heads do not make and lq9 and lq9 it is the pistons. THe lq4 has dish pistons and the lq9 has flat top pistons.
