Why Wont BS3 Turn Fuel Pump On???
Old 02-09-2005, 10:41 PM
2toneblown's Avatar
Default Why Wont BS3 Turn Fuel Pump On???
The BS3 is installed and wired as instructed but it wont tell the fuel pump to turn on. Any have this problem or know why its doing this?
Old 02-10-2005, 10:51 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
Check with whomever you bought it from, mine was not configured to run the pump and I had to send it back to have that done.
Old 02-10-2005, 11:00 AM
JS
JS's Avatar
Theres I/O's that need to configured like John said,its a simple fix...
John hows the BSIII treating u...
Old 02-12-2005, 04:17 AM
BRracing's Avatar
Default BS3 Fuel Pump
The BS3 system comes wired to run a fuel pump relay with either a positive trigger or a negative trigger, depending on your set-up.
Check your harness labels or manuel to determine which style you need to use,and make sure that you do not feed the fuel pump directly, you MUST use a relay.
Buster
BRracing
Old 02-12-2005, 09:23 AM
Green Thunder's Avatar
Buster
BRracing
In the manual it talks about GM fuel pump & Ford fuel pump... The GM (if I remember) is the Fuel Pump HI and is a positive RELAY trigger and the Ford- fuel pump "L" is the negative TRIGGER..
Old 02-12-2005, 10:25 AM
BRracing's Avatar
I believe that is correct. You should have wired a New relay with a heavy gauge feed, and use the positive trigger to close the contacts on the relay and turn on the fuel pump. If you need help with the relay wiring let me know.
Buster
