Conclusion
Old 02-10-2005, 08:08 PM
LS1 Brent's Avatar
Default Conclusion
After doing some research, I have found that I now want to have 15X5 skinnies in the front instead of 15X3.5. In the rear, I plan on doing a 15X8 with 5.5 back spacing. What kind of spacer will I need for the fronts and what is the biggest tire I can use on a 5 inch rim? Will discount tire co. know the right back spacing and everything to install the wheels or is there something I need to tell them? Thanks.
-Brent
Old 02-10-2005, 10:00 PM
LS1 Brent's Avatar
will a 5 inch rim fit on an f body? I just want to be able to stop good and turn okay.
Old 02-11-2005, 12:25 AM
ACW
ACW's Avatar
Here's some threads you might find helpful
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
https://ls1tech.com/forums/wheels-tires/254854-skinnies.html
https://ls1tech.com/forums/wheels-tires/260343-choices-skinnys-street.html
https://ls1tech.com/forums/wheels-tires/243970-weld-draglites-vs-prostar-skinnies.html
https://ls1tech.com/forums/wheels-tires/248971-15x4-prostar-skinnies.html
https://ls1tech.com/forums/wheels-tires/219946-switching-weld-wheel-s.html
Quick Reply: Conclusion
