oil drain back lines from head...pics
Old 02-10-2005, 11:59 PM
2001CamaroGuy's Avatar
Default oil drain back lines from head...pics
well I did what every road racer dreams of......set my heads up for oil return lines to deal with high RPM oil loading in the valve covers.....
I drilled three holes (in each head) and taped them for 1/4" pipe (1/4" pipe to 6-AN line), machined a path along the edge, and prevented most of the oil from going back down the stock way (which includes over the crank).......the lines run down and "Y" into a 10AN block (the 3 6s to a 10) and run back into the pan above the oil level....
could someone post the pics for me?
Old 02-11-2005, 12:08 AM
jrp
SN95 Director
jrp's Avatar
email them to me khadafi3@juno.com
Old 02-11-2005, 12:38 AM
jrp
SN95 Director
jrp's Avatar
Old 02-11-2005, 12:59 AM
thats them.....thanks man
Old 02-11-2005, 01:01 AM
jrp
SN95 Director
jrp's Avatar
your running a high rpm solid roller setup are you not?
Old 02-11-2005, 01:02 AM
yep.....
Quick Reply: oil drain back lines from head...pics
