can i bolt on c5 y2k rims on an lt1
i was wondering if it will work to bolt c5 y2k rims on my 93 z28......is there going to be any problems with it or will it bolt up just fine
Yes and no. They will bolt up, but you will have to take a dremel and brind on the hub a little. Dont worry it wont hurt the rear or the wheel, as long as you dont slip. I had to do that, so they would go on my old 95. If they are real OEM GM wheels you might want to run a small spacer so they are not so set so far back in the wheel well.
