O2 simms on a cammed car???
did a quick search on O2 simms and read a thread which states that O2 simms will not work too good on a car with aftermarket cam and stock tunning because it will lean it out too much. is this true, is there a disadvantage to having O2 simms in my car?could i actually lose power? the simms have been in my car for a while now.
O2 Simms will work just fine in any car... they only exist to trick the PCM into thinking you have working cats
the rear 02s are emissions only... only way you'll lose power is if you installed the O2 simms on your FRONT O2 sensors
