gauge cluster swap question
Old 02-21-2005, 10:23 PM
pwrtrip75's Avatar
Default gauge cluster swap question
can i take a 99 LS1 gauge cluster and put into a 97 V6 car? i know it fits, but it doesnt function properly. can this be recalibrated somehow? who does it if possible and how much does it cost.
thankyou.
Old 02-21-2005, 10:50 PM
wrencher
wrencher's Avatar
Have you talked to Magnus? I know he has first hand knowlege doing this.Maybe PM & see if he can help you out? I do know they are totally different though....
Old 02-21-2005, 11:01 PM
John_D.'s Avatar
Rpms can be recalibrated with a Dakota Digital tach adapter.
Fuel gauge and the other gauges are going to be an issue.
The fuel gauge ohms range changed from 98 to 99. Not sure how it changed from 97 to 98 though.
The 99+ use a "serial bus/data" feed from the pcm. (or something exotic like that).
Just curious, why are you wanting to do this swap? If it's for the speedometer, you'd probably be better off seeing if Granatelli or somebody could rework your speedo.
Old 02-22-2005, 05:03 PM
pwrtrip75's Avatar
my freind has a 97 project hes working on. he didnt have a cluster. But i have an extra 99 one that thaught maybe he could use. but it sounds like he'll have to find a 97 one.
thanks for the info.
Old 02-22-2005, 10:07 PM
Agt. Orange's Avatar
does anyone know if you can use a 97 LT1 cluster on a 97 V6 car
Old 02-22-2005, 10:13 PM
LS1TECH Sponsor
Magnus's Avatar
If you guys are looking for a dakota digital tach adapter, I have one for sale..
Swapping clusters is a mess.. some things work some don't.. need to look at the wiring and the signals that go to each gauge in the cluster to determine what will not work.
Fueling is big change between 98/99.
Oil level signals..
ECT big change between 98/99..
Old 02-22-2005, 10:14 PM
LS1TECH Sponsor
Magnus's Avatar
fyi I use my stock cluster with my LS1.. dakota digital to fix tach.
Quick Reply: gauge cluster swap question
