Gauge wiring.......
Gauge wiring.......
Hey did you guys actually drill a hole in the firewall to run the gauges? I didn't on my 97 but I got the fuel pressure gauge and the wires aren't long enough. If so where did you drill it??
thanks
thanks
I drilled mine under the steering column. Directions say to drill a 1" hole so you can get the wire harness through. I just drilled a small hole, cut the wiring harness off the end, threaded the wires through, and crimped them back together and plugged it in.
Originally Posted by 99FormulaM6
you could extend the wires and go through the hole where the pcm wires go through on the pass side...
