Ready to Order...few questions
Old 02-23-2005, 07:54 PM
KY95Z28's Avatar
Default Ready to Order...few questions
Hello, I am finally ready to order my wheel/tire package after doing a little research.
I am going to go with 2 18X9.5(+54mm) and 2 18X10.5(+58mm) chrome Z06 replicas.
I am planning on BFG KDW's(new tread design) 275/35's for the front and 295/35's for the back. Possibly the BFG drag radial in the back.
Is anyone running these tires?? They seem to be rated really well, but I can't find much info about them.
I will be putting these on my 95 Z28, stock height for now, but I do plan to lower with the pro-kit, bmr or similar. I realize that I will have to do the BFH mod to the inner wheel well, I don't want to run a spacer though(looks or not). If the research I have done on here holds true I should be alright with the 295 and lowered with say the prokit with only the BFH mod right??
Thanks,
Nick
Old 02-23-2005, 08:03 PM
skewba98z28's Avatar
Worst case. You might have to get a adj. Panhard Rod with 58mm offset. If you can get a 56mm for the rear. I think they will work a little better. But if all else fails get a REALLY BFH.
Matt
Old 02-23-2005, 08:13 PM
KY95Z28's Avatar
I just checked, and I believe I can get a 56mm for the rear, so I'll go that route if it'll save me some room back there. I can't imagine 2mm will make much difference, but it can't hurt.
Old 02-23-2005, 08:21 PM
SLIKWS6's Avatar
sorry for the question but whats the bfh mod, thanks in advance and they should look good.
Old 02-23-2005, 08:29 PM
Yeah you wouldn't think 2mm would make a difference but it does.
Here you go man. just remember to read the sticky's before posting. Some tend to be very harsh on here for not searching.
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
Read the bottom of the first post. By the way welcome to the site guys. There is tons of info here.
Old 02-24-2005, 08:31 AM
Xsta Z 28's Avatar
Every MM counts. Try to get 54 mm offset.
Old 02-24-2005, 09:18 AM
KY95Z28's Avatar
THanks for the info,
Anyone have the tires???
