Dry kit and LS1
Dry kit and LS1
Are dry kits ok on LS1's, do the maf do a really good job of adding enough fuel or not? I have a dry kit i put together for my mustang 93lx and never had a problem since you spike the fuel pressure regulator and dont trust the computer.
I have a 15lb bottle, hi-flow valve, 6an line, pro shot noid, 4an nozzle line and a drilled out nozzle, also have a set of 42lb injectors which i assume i could put in w/ a tune. trying to figure out if i should hang onto this stuff and put it on my next car or gather the stuff and make it a wet kit.
yeah...all usuable stuff. THe LS1 MAF and computer is definately fast enough and reliable enough to add the fuel. I used the Green top 42 lb injectors and dual stage dry shots to make 707 rwhp spraying a 300 shot dry right down the MAF. Did it for a long time with no ill effects except worn out main bearings
