Could somebody please look at my O2 sensor readings?
Old 02-27-2005, 12:08 PM
calys968's Avatar
Default Could somebody please look at my O2 sensor readings?
Are these voltage readings from my O2 sensors normal?
Thanks.
File Type: txt
Old 02-27-2005, 12:26 PM
John_D.'s Avatar
The intervals are too far apart to tell anything. They are 5 seconds apart.
I can't tell when you are wot and when you are at part throttle.
It is normal for the readings to continually vary from .3 to .7 at part throttle and idle.
The readings should be in the high .8's at wot.
Old 02-27-2005, 12:28 PM
calys968's Avatar
Ok, thanks. I'll see if I can figure out how to shorten the 5 second interval and then I'll repost some new readings.
