Retainers and high perf valves???
Are all LS1 retainers and valves the same?
That is, if I replace my valves with Manleys or something else, will the standard aftermarket titanium retainers work?
TIA
TIA
As long as you stick with ls1 specific 8 mm valves.
TIA
TIA
I'm sure the manufacturers would disagree with that statement, but basiclly they are mostly the same, as for the retainers it depends on which retains you want to get and what springs they are going on. The titanium ones for stock springs will work with 918's but not with other aftermarket springs, some are spring specific.
