ABS delete
ABS delete
Are there any write up with pictures or anything on how to go about doing this. I have a 3ch and will most likely be getting a 9 inch in a few weeks.
I also heard you can remove the fuse, and that using a blocking plate is only if you want to save the weight. Id like to remove it all if it isnt too much of a pita.
