Question for N2O people
if adapted right, could you use alchy, meth..etc.. instead of gas with wet system? my thinking is, as long as it richens the mixture enough all will be fine and when done right you could possibly get more power from it than with jus gasoline. o yea, and have it reliable too. you could run a smidge more timing because of the alchy and make even more power.
im interested in doing this also
my worry is being able to inject enough meth to keep up with the nitrous.
im hoping that someone would agree that the "safeness" of the methanol would allow me to be able to run around 250 hp or so on my stock bottom end. im planning on using a direct port injection system like the 3rd one on this page: https://ls1tech.com/forums/showthrea...t+port+nitrous
figure i'll have to use a high pressure pump to supply enough meth.
good luck
i'll keep watching...
chris
