All Pro's.....
Any flow #'s/port sizes?
Are these new castings or just ported factory pieces?
Originally Posted by CTSmechanic
Are here picked 'em up last night and damn are they sexy... there going to our engine shop to be tuned up hopefully they'll be done in a few weeks and I'll put up my numbers...
All Pro's should flow close to 300 CFM out of the Box, unported. Once you turn a good handporter loose on them there is no telling where you can go. They come clearanced for Shaft Mounts, Bigger Springs, 3/8ths pushrods, yadda yadda yadda. Also you can get the chamber size any way you want. They're about $1700 bare depending on who you buy them from.
Originally Posted by The Guy in MY 99TA
Where could one go about finding information about the all pros?
Josh S.
Josh S.
Intake
.200 130.4
.300 196.8
.400 244.3
.500 277.7
.600 293.1
The exhaust numbers impressed me
.200 109.8
.300 166.9
.400 214.0
.500 232.6
.600 246.9
.700 254.3
This is an "as cast" head, no porting. I was told there is enought material in the intake runners for a 300cc head. Talk about a head that will grow with you!
SPECS
Intake port 230cc
Exhaust 88cc
Chamber volume 64-72cc
Intake valve diameter 2.02-2.10
Exhaust valve diameter 1.57-1.60
Valve length stdto+.100
OPTIONS
Copper blended seats
7mm bronze guides
O-ring machining for valve covers
FEATURES
3/4" + deck thickness
Improved water passages
More room for increased porting for the newer 421ci + motors
Reinforced for supercharged and NOS applications
Large spring pad suitable for up to 1.625 springs
Strong reinforced rocker pads for less flex andfits updated shaft systems
Large diameter magnum valve seats that will accept up to a 2.150&1.625 valves
Longer, more stable special removeable bronze guides for std 8mm & optional 7mm valves
Suitable for offset pushrods/rockers for a wider port thru pushrod area
Raised rocker rails for improved rocker arm clearance
Specially designed for excellent flow "out of the box"
Redesigned hi-flow chambers
Longer intake face available, so milling head for small chambers is no problem's.
Pricing will be around $1750 w/o parts. This is an almost 300cfm as cast head minus parts (seats and guides are included). For roughly $400-500 more we can sell them complete.
Originally Posted by Richard@WCCH
Rob,
Is the valve guide spacing and valve angle the same as stock? Also, what size valves and test bore were the sample ports flow tested with? Is the spark plug in the standard location and can stock rocker arm assemblies be used?
Thanks,
Richard
Thanks,
Richard
Chris
