Where to buy a 9"
Originally Posted by WS6HUMMER
I have tried Sphoon and Billingsley so far is there anyone else I should try pricing first. Everyone sell 12 bolts but not 9"ers.Thanks
Hummer
Hummer
Originally Posted by matts22
Billingsley is the way to go from what I hear.
Thanks, they are closed til monday so I dropped them an e-mail with a bunch of questions. But I agree with you, the more I reasearch it I see how Billingsly would have a better price for what my needs are. Know anything about the Trach-Tech locker systems that come in them?
They are the most famous locker systems (same as Detroit). Personally, if you drive on the street much, get 31 spline "soft" locker. From what I hear, it drives quite a bit better than the regular locker. And the 31 spline is plenty strong. You won't break that rearend unless you are running rediculous fast. Billingsley has amazing customer service as well...everything I have heard about them is good.
They dont list an option for a soft locker, is it something you have to call about?
http://www.billingsleyracing.biz/Drivetrain_GM.htm
No, if you get 31 spline axles, it will be a soft locker as opposed to the regular locker with 33 spline axles. They only offer one type of locker for each spline IIRC. That would be something to ask Billingsley, but I'm pretty sure if you ordered 31 spline axles you would automatically get the "soft" locker.
do you know how long the shipping takes to get everything?
Originally Posted by BigSteele
why are they closed till monday, that sucks I wanted to try to order it today.
This is TT's pirce with what I want with the exception of the Auburn posi, I'd really rather a soft locker but didnt see an option.
EDIT-Just got off the phone with them there's a $25.00 charge for the locker option
- Spline 31 Spline
- Gears 4.11
- Exciter Rings Pressed (4-Channel Yes
- ABS Setup 4-Channel ABS & TCS
- Rearend Cover Aluminum Case $2,285.00
+$100.00
+$100.00
+$155.00
Sub-Total: $2,640.00
- Gears 4.11
+$100.00
+$100.00
+$155.00
Ok so is there any issues with Gear set up from Billingsley? Gear Whine, bad wear ? etc. I was looking at there Street package with Moser Bolt in housing and Strange center with 31 spline locker and 4.11's. Any comments? I am local so hopefully they will allow me to pick it up. How does this rear compare to a complete bolt in moser rear from Speed Inc?
Thanks,
CMC
Thanks,
CMC
I'm not positive, but I'm pretty sure Billingsley doesn't set them up for the most part. They are setup at Strange, where the center section is bought from. Can anyone else confirm this?
