heater wiring question
the directions that came with my NOS heater say that the thermostat cuts out at 75 degrees. From what i've heard/read, 75 degrees is only enough for 850-900 PSI.
Since I'm running a small shot, i'd like to get the most out of it by running the right pressure (1000+ PSI).
When I ordered my purge and stuff, Cold fusion sent me a pressure switch and adaptor by mistake (in place of a pressure gauge). Their website lists an "1100 PSI pressure switch" so im assuming that's proabbly what i got.
My question is, can i install the switch inline and wire it to the heater relay in place of the thermostat? I figure this would effectively cut my heater at 1100 PSI rather than 75 degrees.
Originally Posted by Y2K2LS1
You could always jet up, and leave the NOS bottle heater how it is.
i could but i wouldnt have a clear idea of exactly how far up to jet in proportion to the bottle pressure. honestly im flat out terrified of nitrous (as most people are before they spray)....im keeping the shot small (75-100).
i can't wait to hit it, but at the same time my car suffers from a pretty bad case of Murphy's Law Syndrome.
