Best wet nozzle setup?
I have a NOS system with a regular wet nozzle setup, its just plumbed into the rubber connector behind the maf. I have read that some wet nozzles are better than others. I plan to run no bigger than a 150 shot, most likely a 100 shot most of the time. I kinda like the TNT power ring, with 2 nozzles, but is what I have fine?
I have also read that some nozzles are better than others with TNT seemingly the best. Their nozzles with the same size jets in them make considerably more power than other nozzles. I guess this is due to better atomization. Thing is their nozzles are not cheap and it's real easy to just 'pill up' on my existing nozzle to get more power even though it may not be distributing it as evenly.
Closed ex-Sponsor Account
Yep I like the MAF kit too.. It got my vote. Now to start mine is better then yours thing. If I had to choice of course I would go with the MAF first then the NX shark single Nozzle, and then I would give my vote to TNT power ring.
Ricky
Ricky
I run a single NX shark nozzle, I've been told that they are good to 250, but the most I've ever sprayed through mine is a 200 shot. I may be switching to a MAF kit one of these days. You can run a 2 stage setup with a MAF kit.
