FMS 30lbers, VE need to be reduced more?
Old 03-06-2005, 08:48 AM
John02SS's Avatar
Default FMS 30lbers, VE need to be reduced more?
With the 30 lb injectors I multiplied the IFR table by 120 coming from 28.8. This seems pretty close, but seems too rich at idle. Did you have to reduce the VE any farther due to injectors? Mine is already at 60/70/80 with a FM13 (230-232). Thanks fellas!
John
Old 03-06-2005, 10:45 AM
DaleMX's Avatar
Try 38, 55, 68, 88 on the VE and see how that works. Good luck!
Old 03-06-2005, 08:52 PM
John02SS's Avatar
Is that 400/800/1200/1600? Thanks for the info buddy. These work on yours?
Old 03-07-2005, 11:37 AM
oange ss's Avatar
I believe the correction should be 125%....I dont know if the extra 5% your gettting would cause your problems
Old 03-07-2005, 05:54 PM
John02SS's Avatar
34.64 at 4 bar/stock 28.8 is 1.2027777777777. This is the calc that several guys have given me and I found myself. How did you calc your 125?
BTW.......The above info on the VE was good info. Ending up 45/55/65/85 and it seems to have helped greatly!
Old 03-08-2005, 10:27 AM
oange ss's Avatar
36/28.8 = 1.25 right ?
Old 03-09-2005, 12:14 AM
oange ss's Avatar
ok, I guess it's not that simple, the correction factor would actually be 1.202....i stand corrected
