Car wont start!
Car wont start!
I believe it has something to do with the key cylinder. I was having problems by putting the key into the car, and turning it. The security light would come on, and I would have to wait 3 minutes until it turned off to try again. Sometimes it would start, sometimes it wouldn't. Now it wont even go to the security light. I feel as if the key cylinder is busted. Anybody had this problem or know how to fix it?
Its a likely VATS fault, Normally if you haven't changed anything in the computer programing etc you will likely need a new ignition lock cylinder and Key. The important thing is to have someone at a dealer or who has the resistance tables to code the key pellet value. The value most match so the VATS module stuffed in the dash matches. Once a VATS module has a value burned in as yours has that value it must use for life of the module.
I have the same deal going on. The car would not start some times, then it wstarted every time, but the security light was on. Now, the car is dead & won't start with either key I have. I messed with it for over an hour tonight, still nothing...
Looks like it needs an ignition cylinder.?. Is this a dealer part only or can i get a locksmith to come out & fix it?
Thanks!
Thanks!
