tach problem
tach problem
guys,
installed an autometer tach on my 2000 ta. i spliced the fraid wire in the red pcm pin #10 (white wire). Nothing happens... The tach is set for 4 banger... could it be the splice... I did the oll cut`em and wind`em... Maybe i should salder them, but even so, shouldnt i reed something????
ok, that's the right connection then
10
WHT
ENG. SPEED (TACH) OUTPUT SIGNAL
RED connector
I've never wired one up so not sure what else to check... but we know the right wire was spliced..
10
WHT
RED connector
Sorry about the hijack, but wanted to ask Mike a quick question.
Mike, did you have any problems like this poster hooking this tach wire up to the LM-1?
Thanks.
Thanks.
