Check engine light
Could it have been the air check? Not switch? If it happens to be an air check valve they are very easy to replace and cost around $10. Air switch valve is not ringing a bell for me.
You’re going to need to give the pxxxx number code to us. Should be something like p0101...
What scan tool did you pull this code with? Handheld scanner?
