Resizing stock rods, over size bearing?
I am having my rods resized meaning they are going to drill the hole out bigger, Where on earth can i get an LS1 rod bearing that is for a standard sized crank, but oversized actual rod.
I can shift faster than you.
Nearly all the bearing manufacturers make a bearing for this application. The ones I use frequently on the re-sized stock rods are from Clevite.
The part # is CB1776A. According the catalog I have, they are not available in a STD bearing (older Clevite catalog). The ones I have always used were +.010".
the reason i am haveing them resized is because i am going to ARP bolts... and i have been hearing alot of people have to have them resized. I have 16 stock sized rods. Hopefully i can get 8 that i will not have to have resized, if thats the case i'll just buy standard bearings, and call it a day.
