Tuning STS Turbo Car
I have tuned a few LT1 NA cars in the past with good results. I just got LS1 edit, and have the STS turbo kit installed. The car has 60lb. Mototron injectors. I would like to know where I should start with the tuning, or if there is a FAQ or info sheet like there is for tuning NA applications. Also why does the injector constant look weird, LT1 edit had the actually lb/hr rate listed. Will this turbo kit max out the mass air sensor? Is it safe to assume the stock MAP sensor doesn't read positive manifold pressure?
