how to disable DFCo
Old 03-23-2005, 04:13 PM
cablebandit's Avatar
Default how to disable DFCo
I want to totally disable DFCO when at the track. I dont like the idea of the injectors cutting off after a run in my turbo car...I'd be fine to waste the fuel and cool the cylinders. What settings would disable it completely as they are kind of confusing....this is with Hptuners btw.
Old 03-23-2005, 04:57 PM
Another_User's Avatar
Set the enable temp to 258 degrees, and change the timing TPS disable on table B to 0 percent. That will take care of it for sure.
Old 05-10-2005, 10:58 AM
WS6FirebirdTA00's Avatar
i see enable normal and clutch transition and the tps table b entry. so i change the b entry from 99 to 0, the normal to 258*, do i put the clutch transition to 258 also or will the DFCO enable normal entry take care of that?
Quick Reply: how to disable DFCo
