85mm MAF - which one?
Old 03-24-2005, 01:19 PM
Tech's Avatar
Default 85mm MAF - which one?
This is going on a big H/C automatic car with big stall. He's going to order the FAST 90/NW 90 and needs a larger diameter MAF. Who is using the Pace calibrated MAF and who is using the GM Z06 MAF? Any problems with either?
The car will be tuned.
Old 03-24-2005, 01:22 PM
horist's Avatar
I'd go w/the LS6 MAF (not the SLP one w/the resistor) and use the LS6 MAF tables to start
Old 03-24-2005, 02:51 PM
Slow 346's Avatar
I have one for sale if interested too!
Old 03-24-2005, 03:05 PM
Tech's Avatar
Where in IL are you? Why are you selling it? I'm in St. Louis.
Old 03-24-2005, 09:49 PM
Tech's Avatar
Anyone else have input?
Old 03-24-2005, 10:15 PM
BAM-BAM's Avatar
i have the pace one for a year and a half with no problems at all.....
98 ss a4 383...4000 stall 373 gears ..on and on and on...
next week i will be adding that exact setup fast 90 / nw tb and 42 lbs injectors and retuning.....changing from my ls6 and ported tb...i will have dyno results on the 4th.of april as long as the weather holds out...
