New Rearend Purchase Delays?
Old 03-24-2005, 11:05 PM
Billingsley Racing's Avatar
Default New Rearend Purchase Delays?
If you have a 4 channel ABS/TCS system on your 98-up f-body and can't afford the downtime of re-using your stock ABS speed reluctor wheels, we have new GM units in stock for $69 pair. These can be used on both Strange and Moser rear ends and will save much time and many headaches.
Thanks
Old 03-25-2005, 07:56 AM
TRex's Avatar
What about sources/prices for backing plates and caliper brackets ? This would prevent pulling the axles at all.
Old 03-25-2005, 12:40 PM
We have these as well from GM. They are $229 pr.
Thanks
Old 03-25-2005, 12:48 PM
TRex's Avatar
Thanks for the info, looks like it might just be cheaper to buy a complete used 10 bolt though
Old 03-26-2005, 11:49 AM
BigSteele's Avatar
if you buy the backing plates do they come installed with the bearing pressed on?
