How would these fit on my ride
19x10 with +48 offset with a 7 3/8 back side on the rear of the car
19x8.5 with +46 offset with a 6 1/2 backside on the front of the car
If they line up right what tires would fit as well, the car is stock hight...Thanks
I think the rears will be close. A lot of guys run 11" in the back and you're going 10", but you're compensating by having the +48MM offset instead of the usual +50MM which is found on 17x11 ZR1's. The front's I'm not 100% on maybe someone can chime in here.
After reading the "Does this fit" thread I believe the fronts MAY work, but it looks like you might have to use a BFM.
