Solenoids in trunk??? No heater on dry setup?
I've got a couple questions:
What is the downside of mounting noids right off the bottle? I figure there will be a small delay after the nitrous is activated, but cant that be made up with a little bit lower RPM on the window switch?
Also, with a dry kit, is it necessary to use a heater to increase pressure? I figure that as the pressure falls off, the injectors will adjust accordingly, correct?
Just trying to keep the setup as inexpensive and simple as possible.
