wideband 02 questions with hptuners
1: doe anybody make a wideband o2 that you can just put in place of the current narrowband o2???
2: will it show up in HPTuners as a Mvolt reading so you can do wideband tuning on it
3: how fast or at what intervals does the HPtuners report the Mvolt reading from the 02 sensors
just curious cause I am buying HPTuners here in the next week or two...and I want to start tuning
http://www.innovatemotorsports.com/press/pr-lm1.php
The sensor can be used in analog mode with EFI live. Its better used with the handheld device to get use of the fully digital mode.
LS1TECH Sponsor
You need an extra device to keep your wide band alive. A wide band without a controller will not last too long.
You can log it as volts or AFR.
3: how fast or at what intervals does the HPtuners report the Mvolt reading from the 02 sensors.
All AUX inputs are logged 40-50 times per second, and then averaged over the period of 1 PCM frame to give you your AFR for that instance in your VCM Scanner log.
