What fuses pulled for idle relearn procedure?
IDLE RELEARN
PCM relearn Quick & Dirty method:
1) Pull the PCM BAT and PCM IGN fuses.
2) Let car sit 10 minutes
3) Turn Key to on and then turn off
4) reinstall fuses
5) start engine
6) allow to idle for 2 minutes in park, then 2 minutes in drive, and 2 minutes in reverse.
7) repeat #6 if you have time or if the idle felt rough.
4) reinstall fuses
5) start engine
