need help after th400 install
Old 03-29-2005, 08:57 PM
sprayinss's Avatar
Default need help after th400 install
i just went from t56 to th400,i have a 400 stahl and a big cam,with no speedo hookups,will i need to have pcm tuned in order for it to run rite,its real sluggish now thanks
Old 03-29-2005, 09:37 PM
Coal Mining Director
onfire's Avatar
No ecm issues with the t400 from a mn6. Did you tune for the cam? That will need a tune.
Old 03-31-2005, 05:00 PM
BLK02WS6's Avatar
Don't know about the M6 conversion, but with my A4 to TH400 conversion and no speed sensor, I wasn't getting any timing at all (10* at WOT). It was forcing to the Park/Neutral tables even though the TPS was >0. Might wanna log it just to be sure you aren't getting the same problem. I've heard it is not so on M6's, but might be worth a few minutes to see.
