Trans wont reverse
Trans wont reverse
i just put the trans in i had every thing going go so i put it down and reversed back well then my drive and od wasnt working it wouldnt go into get so i would i have to shift manualy so drove it around the block drive was still not working so it had reversed fine at first but then i notice that drive and od was working but now reverse wasnt and now when i put it in nuetral and it goes forword and when i put it in park it lunges forward i dunno i just about had it with this trans someone please tell me what the hell is going on cause i dont
Originally Posted by James B.
What was the transmission out for in the first place? A 4L60-E with a shredded sprag behaves like you have described.
They will get stuck in gear alot of times with these symptoms. Sure you plugged that back in Juan two Three?
Mike
