Removing gear from crank.
Old 04-04-2005, 01:09 PM
v8maro's Avatar
Default Removing gear from crank.
What is the easiest way for removing the timing chain gear that is pressed onto the crank? Also, how do I go about installing this on my new shortblock?
thanks
-Steve
Old 04-04-2005, 01:11 PM
777's Avatar
use the pulley puller on the crank gear as well...that is what i did...it slid right off...to put it back on you just slide it on...then when you torque your oil pump down it will pull the crank gear all the way on...
