Need some help with A/C system...
Old 04-06-2005, 07:56 AM
v8maro's Avatar
Default Need some help with A/C system...
Ok, during my last cam swap I broke the line going to my A/C Condenser, see pic below for which one and where I broke it. What is this line called and what is the part number for it? thanks
-Steve
Attached Thumbnails Need some help with A/C system...-untitled.jpg
Old 04-06-2005, 12:07 PM
GM Muscle's Avatar
It's P/N 10282758 . They are $30 from GM parts direct. I bet someone would have one cheaper if you posted in the Wanted section.
BTW: GM parts manual says it's a A/C EVPR tube.
Old 04-06-2005, 01:31 PM
Camaroguy's Avatar
-Steve
On my last cam swap about 2 weeks ago i broke that same hose in the two places you have marked. My first cam swap i guess made that line weak and the 2nd cam swap finished the job.
The part number above is correct, but i think you will also need the rubber seal which is part number 52477087.
The three things i will be ordering is
(1) 10282758 ($28.35) actual line that broke
(2) 52477087 ($3.27) the rubber seal
(1) 10245620 ($3.10) the electric piece (CAP & SEA)
I believe this is the complete setup. or at least that is what i will be ordering from them.
Old 04-06-2005, 04:48 PM
GM Muscle's Avatar
The manual said that those are inlcuded with the tube. Wouldn't hurt to order them though just incase.
Old 04-07-2005, 07:05 AM
v8maro's Avatar
Wow, you guys rock, helped me out more than I expected. Thanks!
-Steve
