question
Old 04-06-2005, 06:36 PM
tboysen00's Avatar
Default question
may be a stupid question but do i have to remove the ac condensor or can just move it out of the way or can i just not do anyhting with it. do i have to reinstall ac freon. thanks troy
Old 04-06-2005, 06:39 PM
snake charmer's Avatar
what are you trying to do?
Old 04-12-2005, 09:05 PM
tboysen00's Avatar
sorry put a cam in
Old 04-12-2005, 09:08 PM
GMTECH's Avatar
Originally Posted by tboysen00
sorry put a cam in
Somebody correct me if I'm wrong, but from what I've read you can just get someone to hold it out of the way. But be careful not to bend the hoses. Check out Ls1howto.com. TONS of good info on a cam install.
Old 04-13-2005, 11:40 AM
TARyan21's Avatar
NO you don't have to take it out or add freon. Just have a buddie pull it to the side gently! You will have plenty of room. Remember that the lines are not that strong so gentle is the key. Refer to LS1howto.com for the instruction manual. This is what I used and it is awesome. Np problems what so ever.
Old 04-13-2005, 11:53 AM
Cal
Cal's Avatar
I used a bungie cord to hold it to the side since I don't have friends . . .
For the second cam install, I said "to hell with this" and removed the a/c system and left it off.
