Drag Racing Results - low 13s high 12's? w/drag radials
View Full Version : low 13s high 12's? w/drag radials
stangkillerWs6
04-07-2005, 04:05 PM
i have a 2000 ws6 a4 and i went to the track last week an ran a 13.5@103 w/ a 2.07 60 ft i want to buy some drag radials i was just curious how much they would cut my time down and
LEVI'S-TA
04-12-2005, 06:47 PM
how bad did you spin on that 13.5 pass? and if your stock a 2.07 60ft ant bad on street tires.....
Roarin_8
04-13-2005, 01:58 PM
Depends on track prep and weather. I managed to cut my best 60' @ 2.017 but only mustered up a 13.43 with it. Still haven't beaten my best yet. Also on the same street tires as my best run.
blkZ28spt
04-13-2005, 04:47 PM
Might drop a tenth or two.
potholesrbad
04-15-2005, 02:08 PM
what ever time u pick up on your 60' double that and that will be the time you pick up in the 1/4 mile so if you ran a 2.07 and you run a 1.97 on drag radials you should go from a 13.5 1/4 to a 13.3.... what mods do u have if any?
blkZ28spt
04-15-2005, 02:35 PM
I had always heard that you could do 60' to 1/4 mile that way....but when I first ran my car at thet rack I had 2.0 60's and ran 12.9. Went back with some minor adjustments and better launch technique. Ran 1.72-1.75 60's and 12.6's. Dropped ~0.25-0.3 from the 60' and ~0.3 from the 1/4.
potholesrbad
04-15-2005, 04:56 PM
i was told that too and all the #s were right for it to happen except it was braket racing and i hit the brakes hard at the other end went 2.3 60' w/ 14.7 @93 then went 2.02 w/ 14.67 @81 1000' was same as friends mustang who ran a 14.08 his car has continued to run the same mine got built motor and then blew up after beating a mustang that ran 12.9 @ 81 on drag radials witha 1.9 60' couldnt get the tranny to shift into od and the blower belt blew off never ran the built motor at the track though :(
