Weiand Aluminum LS6 Intake
What do you guys think about this intake, for about 550 in the future I will be going 200 wet shot direct port? How will this intake do
I had the weiand intake for a couple of weeks and took it off to put a ported ls6 intake on. The problem is it get's heat soaked pretty bad. After sitting in traffic I could tell a SOTP difference in power due to the heat soak.
-Sly
-Sly
its an overweight piece of ****!
why would you want a 25lb intake that will gain 10rwhp
when you can get a 2lb intake that will gain the same, without the heat soak!!
