90/90 setup
90/90 setup
Anyone else besides FAST make the 90/90 intake manifold/tb setup. Have heard some negative things bout fast, and wanna explore my options.
dunno bout 90mm manifolds but Nick Williams makes 90mm TBs and i think Bo White, and a few others.
Havent heard of any other 90mm intake comin out but I think the probs ur hearin about is the FAST TB fitment to the FAST 90mm intake and the TB blade stickin. Havent heard anything bad about the manifold itself.
NX has just come out with an 85/85 setup! you might wanna check that out
You can always do the LS2 intake conversion, it's 90/90. Also TPIS has an oval throttle body you can use, they modify an LS6 intake and bolt one on and get some pretty decent results.
-Sly
-Sly
FAST is the only one that makes a 90mm intake, other than the LS2 intake which has shown questionable results. As far as a 90mm TB, FAST, TPIS and Nick Williams make them. I'd recommend the Nick Williams one.
