BMN window switch question
I am in the middle of wirein up my nx single nozzel kit. i saw the attached image posted on a thread and was wondering this is right to do. The instuctions i recived in the box are not like this wire diagram. i was just wondering if somone wired it like this and it works ok? Thanks
That is the easiest way to wire in the window switch to an NX. The FPSS is supposed to go to ground. It gets hooked to the window switch instead. The window switch gives a ground to the circuit when in the choosen RPM range you want to spay.
