All pro heads, who's running them?
as the title says, requested some info from all pro in regards to these, and received the catalog.. looks like they can be custom cast?!? Different valve angles, all kind sof stuff. Anyone out there running a heads/cam setup and using these heads? If so, post up your results, looking for some info.
SSU'S Vice Mod
They've already tested the AFRs and results are in the section. It's nice that Kurt is doing the work for us. JL, you raise an excellent point with the revised valve angles and that's something I'm getting ready to post up about over there right now.
