which injectors?
which injectors?
Ok I know I'm asking the same question but I'm a little cornfused about what to do. I have a 99 with the mods listed. 75k on the car needs fuel filter changed and Oregon is notorious for bad gas. I want to get new injectors as well. I know I can just have them cleaned but thats going to be like $150 at the dealer. I saw another thread that suggested stock 28.8#'s are cheap now? would this be a good upgrade for me( 99 has 24.6?) and will I have to adjust the pc to the new injector? I see Accel 30# injectors for $295.60. What should I do ?
Your stockers will be just fine for your mods you will need to retune if you change to anything else. If you want to retune then by all means change to a bigger injector for future mods.
Nate
Nate
Nate
Nate
