Safe timing with NOS 01577
Old 04-24-2005, 10:36 AM
pla-tym's Avatar
Default Safe timing with NOS 01577
If I run a 100hp shot what would be safe timing levels? I have it at 28* total right now.
Old 04-24-2005, 06:05 PM
12 Second Truck Club
Magic Chicken's Avatar
From the FAQ that is stickied at the top of the forum:
Q: What are some of the general rules for even higher HP gains?
A: Generally, forged aluminum pistons are one of best modifications you can make. Retard ignition timing by 4-8 degrees (1 to 1-1/2 degrees timing retard per 50 HP gain). In many cases a higher flowing fuel pump may be necessary. Higher octane (100+) racing type fuel may be required as well as spark plugs 1 to 2 heat ranges colder than normal with gaps closed to .025"-.030". For gains over 250 HP, other important modifications could be necessary in addition to those mentioned above. These special modifications may include a forged crankshaft, a high quality race type connecting rods, a high output fuel pump dedicated to feeding the additional fuel demands of the nitrous system, and a racing fuel with high specific gravity and an octane rating of 110 or more.
Old 04-24-2005, 07:08 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
You should call an expert such as Futral, Thunder, APE, W2W, HPE, NOS, NX ,etc. and ask them, rather than take a poll on a web site. JMO.
Old 04-24-2005, 07:33 PM
pla-tym's Avatar
Thanks for the info...
Old 04-25-2005, 12:22 AM
Robert56's Avatar
Three 5177 kits and ran stock timing on all at that power level.
Old 04-25-2005, 08:55 AM
Z284U2TRY's Avatar
Are you saying on the spray your timing is 28? Mine usually runs about that n/a and when I hit the spray I end up around 24. dry shot
Old 04-25-2005, 06:45 PM
pla-tym's Avatar
28* is what it is n/a
Thanks
