will it work ???
will it work ???
I have a tune for the STS turbo from a stock 99 A4 Camaro SS. My car is a 2001 Z28 M6. will it work and how should I go about it? I am simply trying to get a starting point then I can fine tune. I am using HP Tuner. Thanks for your advice.
~Guy
~Guy
~Guy
~Guy
your 01 also has 28lb/hr injectors stock, a 99 has 26lb/hr ... so it will require tweaking ... the VE tables will be different as well as mentioned... since the 01+ have the LS6 intake manifold and smaller cam than the 98-00 cars...
The A4 stuff can be removed.. but you'd lose reverse lockout I think?
wow you guys are awesome. thanks for the info. so what I gather is I can copy some of the tuning numbers over to my original .bin file and start with that then fine tune from there ??
