A4 - M6 Question
A4 - M6 Question
I need to know what kind of a connector to make to connect my Clutch switch. I have the wires run over there but I don't know what kind of connector to use. If anyone has any info on this let me know. Also what did you use to plug the reverse lockout connector as i won't be using mine?
are you talking about the switch underneath the clutch pedal? There should be a couple prongs on it and you can just use those generic slip fit connectors. I can't remember what they are called but they will slide around the prongs on the clutch switch and then you can crimp them on with a pair of pliers. I didn't plug my reverse lockout connector and haven't had any problems.
I don't know what connector you're referring to, however contact Rodney at RPM transmission, he has a wiring guru next door that built mine from scratch for my conversion and it works perfectly.
