Hp Tuners
HPtuners is like LS1Edit...it's very versatile tuning software. You can change many different parameters in your PCM such as editing fuel trims, timing tables, disable engine codes, shift points, etc. If you get the right people behind the computer screen and your car on a dyno, you can get 20+ HP on tuning alone.
HPTuners is also a scanner/data logger. You can run it at the dragstrip or just cruising around & see a heck of a lot more about what the car is doing. I find it extreamly useful for recording my runs at the track. You can see things like when knock retard is on, what timing/fuel parameters the VCM is hitting the motor with & such.
