Which Cam?
Which Cam?
Have a 2002 6M SS,just put a magnaflow catback on it and I have hooker LT-stainless steel,magnaflowcats and y-pipe sitting in the shed to go in this saturday.Question is looking for a good street cam not to radical and must be streetable and I don't want to have to make computer modifications.Thanks for any help, please list name of company and part# if you can thanks.
i heard the ls6 hot cams are pretty streetable..as far as i know most cams need computer tuning to get the most out of them.. but i wouldn't think that cam would need too much tuning.. i am not sure though.. but..
I have a Futral F11 cam and i like it a lot so far.. just need to get the tuning right.. If you want the most for your money get futral or another sponsors cam.. www.futralmotorsports.com , call Allan or Candy or e-mail them and they can help you out and get you exactly what you want! They are great people.. do some searching and you'll see all the good feedback on futral! Good luck
My recommendation is the MTI Stealth II if you want stock driveability...its a 224/220 reverse split on a 116LSA. Has put down 400+rwhp/380+ torque on stock heads on an A4 before. And you shouldn't have to modify your computer.
All cams (all mods for that matter) will need pcm tuning to make it worthwhile. What is the point of adding mods for power if that power is not reached because of lack of tuning?
I made 404rwhp/383rwtrq with the Stealth II. Nice cam. Pcm tuning needed for fuel trims and shift points/limiter. That cam pulls over 6600, but I shift there to fall in my verter shift point range.
