Checking Compression
Old 04-29-2005, 01:35 PM
Camaroguy's Avatar
Default Checking Compression
When checking the compression on each individual cylinder what is a normal number to achieve? What is too low? How long does the compression need to stay about 3 minutes? or just check it and move onto the next one?
Example, between 180 and 210 on compression in each cylinder?
Old 04-29-2005, 02:46 PM
Camaroguy's Avatar
anyone?
Old 04-29-2005, 02:50 PM
Cal
Cal's Avatar
It varies with camshaft design. Usually you check all of the cylinders, and see if they all read within 5 to 10 % of each other. One thats a lot lower than all the others is suspect.
