How long is a Spec 3 carbon supposed to last?
I have had mine for 25K miles or VERY abusive driving and it still grips like a ****!
Is that normal? It has never slipped once. I did however use my own pressure plate vs the Spec PP. Would that have anything to do with it?
I am going to take it apart soon and check it out.
Originally Posted by xaon
my spec 3 carbon lasted for 35k miles and 40-50 6600rpm in a car pushing 410 to the rear wheels.
how would you rate the streetability for city driving (does it chatter etc.)
Originally Posted by bluecmaro96
whats the difference from spec atge 3 regular and the carbon? and if i just have longtubes and exhaust should i get a spec stage 2? or a stage 3?
Just shoot SPEC an e-mail and they will answer your questions....just give them about how much power you have, weight of your car, and how you intend to drive it.
the "F" carbon material upgrade is about $150, and should increase holding power about 100 tq if I remember correctly what I just read
Whats the streetability difference, anything noticeble?
Originally Posted by BigSteele
what PP did you use? why?
I used a borg and beck PP, at the time the SPEC clutch sets were still using the modifued stockers that were popping left and right. This set up gripped perfectly with 550+ft lbs hitting it and still never skipped a beat. Has this weird growning type chatter in the mornings when it;s cold but goes away quickly.
