19" x 10" C6 Rims Outback?!?!
Old 05-03-2005, 01:29 PM
XxXTransAmXxX's Avatar
Default 19" x 10" C6 Rims Outback?!?!
Hey guys,
I was wondering if any of you knew why the 19" x 10" Rim on the C6 wont fit out back. They are telling me the biggest I can run out back are 18" x 9.5". Which I had in my C6's but got rid of cuz I want more meat out back for the motor being built. He's saying the 10" is too big that it'll hit, but yet we can run the 11" ZR-1's out back?!?!
Old 05-03-2005, 01:58 PM
1badls6's Avatar
I have seen a ss rolling around with the 19 x 10 c6 wheel on the back and the 18 x 9 on the front.
Old 05-03-2005, 04:33 PM
Tally TransAm's Avatar
the offset is WAY off if im not mistaken
Old 05-03-2005, 05:26 PM
burnout04's Avatar
there is a guy on here running a lowered z on 20x11's in the back and he has no problems
Old 05-04-2005, 02:31 PM
IntroWheels's Avatar
The offset is all wrong on the C6. The C6 wheels have a more positive offset than the C5 wheels that everyone knows can fit on the Camaros and whatnot.
Old 05-06-2005, 12:53 PM
buck2769's Avatar
I would be interested if anyone has accomplished putting this tire in the rear as well. I recently purchased some OEM C6 wheels and would like to know if I'm going to have to use a sledge hammer.
Old 05-06-2005, 01:05 PM
Hey Buck, bolt them up on the rear and take a pic for me to show me how much they stick out past the body can you? Email me them to me @ XxXTransAm2@aol.com I have no problem clearancing the inner well I just don't want it to stick out redicuously past the body
Old 05-06-2005, 01:10 PM
OEM c6 wheels will not fit an fbody
Old 05-06-2005, 08:42 PM
ROCNDAV's Avatar
I'd like to see those pics too Buck.
David
Old 05-07-2005, 11:09 AM
racrx's Avatar
see sig...its all in the backspacing
Old 01-11-2007, 11:47 PM
Z28golfer87's Avatar
Default Finial
So the finial word is that the 2005 Corvette C6 rims wont fit on Camaro’s? Correct?
Old 01-12-2007, 12:40 AM
michaelg589's Avatar
I know theres someone with a Formula on here who fit 19x10s on his car. I think the offset was +79mm. which is WAY too much for an f-body. He ran like a 1" spacer or something like that. Hopefully hell see this thread and add some info.
Old 01-12-2007, 09:32 AM
Xx01CamaroZ28xX's Avatar
+2 on some pics Buck, but im gonna have to agree with Tally on the offset being COMPLETELY different. You might be back on the hunt for some new wheels again buddy.
Old 01-12-2007, 09:33 AM
ls2 bait's Avatar
u will have to buy large spacers. like 1". similar to the s10 guys with 4th gen wheels. teri's white ss has oem c6 wheels on it and there is a write up in this section if u search of a guy who put them on a formula.
Old 01-12-2007, 02:49 PM
GlennNo50's Avatar
I have 19x10 C6 wheels on my SS but they are not the corvette offsett. I still had to beat the fender well a little so they wouldnt rub during cornereing. Only about a 1/4 inch or so. Took less that 30 seconds per side. I do not know what brand they are as I bought them used.
Old 01-12-2007, 03:23 PM
Deep Blue's Avatar
I put my OEM C6 rims on almost a year and a half ago. As many have commented, the offset on the rears is too radical. Incidentally the fronts are 18X8.5 not 18X9.
18X8.5 = 56 mm offset
19X10 = 79mm offset
The fronts will fit just fine. For the rear 19s, I bought some some 1.25 inch wheel hub-centric adapters that bolt on to the hub. If you are simply going to use a spacer, you will need a custom design or longer studs.
Of course now there are a number of C6 reproductions in FBody friendly offsets
Quick Reply: 19" x 10" C6 Rims Outback?!?!
